Case recommendation
20 Oct 2002
Space, the final frontier
Hi,
Could someone suggest a case to hold the following
4x 3.5 SATA
4x 2.5 SSD
Then the following
P9X79 Pro
3930K with H100i
290x and 7970
1000w Leadex PSU
PCI-E Soundcard
All to be air cooled
Thanks
Well i currently have the Corsair Carbide 400R
£100-£150 in an ideal world, dust filters are a must
Thanks
Thanks for the recommendation, looks like the right one for me, just need them to get them back in stock, just like the H100i
Can anyone recommend any fans for this case? I will have the H100i and then a 290X and a 7970 in the same case
Thanks
Well I was thinking of getting this CPU cooler now
NZXT KRAKEN X61 AIO Water Cooling Unit
And for case fans...
Bottom/Rear - 140MM fans, i was looking at Corsair / NZXt but they are always sold out
Front - 200mm of some description, low noise high airflow
around £15 a fan, maybe more if its worth it, £20 tops
