Case recommendation
7 Dec 2011
Hartlepool
Im after a case ive put a budget of around £100ish. The components I have now are in the sig plus the i5 is delided and cooled by a h55 with noctuas in push/pull. My main concern is keeping it all cool plus looks and a large side window. Oh also the mobo is mitx but I'm after a large case as I'll properly be upgrading later and maybe jumping to a custom loop water cool.
Any suggestions please?
The fractal define s is on my list as is the carbide 400c and nzxt h440 (not sure on window). How is the build quality on fractals?
Fractal build quality is exceptional IMO. I have an Arc Midi R2 and an Arc Mini R2 and both are built extremely well. I also have an NZXT H440 which is also excellent.
Another quality case is the Phanteks Evolve.
How is the cooling on the h440? As I've read on forums about bad cooling. I don't understand why as the specs look great.
I went to pull the trigger on this but its out off stock. Phanteks Enthoo Evolv ATX Mid Tower Case - Gun Metal
+1 for Phanteks cases. I've got one of the big brother full tower variants, but very happy with the overall cooling options of the brand.
I recently picked up a phanteks case from the MM, they do seem like a lot of thought has gone into the layout to make things easy to put together. Them INWIN cases do look like a case to really show off your PC though if thats what ya wanna do.
edit, i just saw another thread about an phaneks evolve case, the cooling design for the top of that doesnt look very well thought out if your planning on mounting a rad up there so i would make sure your CPU cooler would reach the front slots if you look at that one.
Thanks for the suggestions guys. I've oread the corsair 400c and should be here tomorrow. Also order a aerocool qs240 for behind tv in living room it's a great little case for the money.
