Case recommendations for Unraid server
6 Nov 2002
Looking for recommendations for a case I can use for an unraid server I'm putting together with existing parts. Need to fit in 4 X 3.5 and 2 X 2.5 drives, full size PSU, matx motherboard and a gtx1070. Don't care what it looks like as it'll be sitting in a rack out of the way, but the more budget friendly the better! Any ideas?
Why not Just buy a 4u rack atx case … it’ll slot right into the rack, be designed for front to rear air flow, will have loads of hdd bays and will be cheap.
I had 2 the weight and space they take up have now moved to a fractal r6 which can hold like 11 3.5" drives and 4 2.5" much cooler and easy to move around.
4u rack is OK if you have lots of smaller drives had bunch 2tbs back then now all mine are 10tb+
Node 804, edit just googled, if you can find stock that isn't stupid money that is
