- 19 May 2014
I'm about to embark on building a couple of high end (ish) PC's for work (they will both run 12700K CPU's, 64GB ram, Noctua D15 coolers, Quadro RTX4000's etc. The only thing I can't decide on is the case.
I've been looking at cases for a while and the only case I like the look of is the Coolermaster SL600M which is no longer available. I don't want anything with loads of rgb as they will be work systems, and want something a bit more 'grown up' looking.
Key requirements are: enough space for the Noctua cooler, 'office'/'professional' look to them, decent build quality as these cases will likely be used for the next few revisions of these systems, and relatively quiet.
Would really appreciate recommendations. Currently leaning towards either the BeQuiet 802 or the NZXT H710.
