be quiet also do some decent cases if you want quiet but a bit more expensive than Kolink!Oh, and as quiet as possible!
I'd probably go with that first one you linked to be honest! I'm not a fan of RGB/LED cases myselfThis is what I wanted: https://www.overclockers.co.uk/be-quiet-pure-base-500-midi-tower-case-black-ca-13p-bq.html
And this is another option: https://www.overclockers.co.uk/be-q...ower-case-black-tempered-glass-ca-13w-bq.html
Budget about £100.
Any other suggestions?
Ah my apologies.Out of stock no ETA. That's why I'm asking.
Ah my apologies.
You can get a metallic grey one that is in stock?
be quiet! Pure Base 500 Midi Tower Case - Metallic Grey
Order be quiet! Pure Base 500 Midi Tower Case - Metallic Grey now online and benefit from fast delivery.www.overclockers.co.uk
Or one with a window for slightly more but still in black?
be quiet! Pure Base 500 Midi Tower Case - Black Tempered Glass
Order be quiet! Pure Base 500 Midi Tower Case - Black Tempered Glass now online and benefit from fast delivery.www.overclockers.co.uk
I'd recommend the Lian Li Air Mini personally. A bit more expensive, but scales well to any hardware. It fits my 4080 FE a treat on an matx motherboard. I like the adjustable back plate as well
Every case I've owned has been silent. Its only once I put stuff in it does it start to emit a noise!Oh, and as quiet as possible!
Lian Li Lancool 216 Mid-tower PC case - Black
Order Lian Li Lancool 216 Mid-tower PC case - Black now online and benefit from fast delivery.www.overclockers.co.uk
If going for an air cooling build
When I had this case I could hear them at full speed. But I used a 7v cable and they were quietNice. How loud are the fans?
