Case recommendations similar to S2?
10 Jan 2016
hi there guys, I thought id ask here as you guys are a great. After xmas im looking to get a new motherboard and case. Ive been looking at the Define S2 Blackout Midi Tower Case, which has quite a few things I like;
- No 5.25"/optical bay (so larger area for front fans),
- HDD tucked behind but not at the bottom of the case (infront of psu, as I have a long PSU - EVGA P2 1200w),
- Support for 140mm fans - 120mm are okay, but prefer 140mm,
- The abilty to chuck my 280mm AIO at the top,
However, the only thing I did like too much was the top section. The grill section (at the top), didnt seem the best - its not a magetic mesh, just a gril. Somewhere I saw, the gril doesnt fit that well? I wonder if you guys have any suggestions for cases? or have the S2? maybe the gril is fine?
The AIO could go at the front, allowing the top cover to say on - although is only fan exhasting going to be enough?
many thanks!
The Anidees Crystal XL is somewhat of a scaled up S2, but with more tempered glass.
Can fit pretty much anything up to a Dominus and dual 480 radiators.
It is however very big, and very heavy.
