Case recommendations
7 Mar 2014
I am looking to buy a case that will fit a Micro ATX with a long graphics card within a budget of anything up to about £50
Preferably I'd like something minimalist that isn't covered in LEDs and flashing lights etc. Having said that I am willing to sacrifice looks for something that is efficient in terms of cable management and cooling.
Cheers
Laurens
For a good gaming mATX case you're probably looking at around £70. The Aerocool Dead Silence, Xigmatek Aquila, and Bitfenix Prodigy M and Phenom M are all around that mark. All four can fit long GPUs, although for the Bitfenix cases you need a PSU shorter than 160mm. The first two would be better for cable management and cooling.
Thanks, those might be a bit over my price target though.
Any suggestions for larger cases that would support a mATX board?
The only one I've looked at so far is the Antec Three Hundred Ultimate Gaming Case
Something within that price range would suit me better.
Thanks again for the response
Available Color Midnight Black / Chocolate
Materials Plastic bezel with mesh, steel case body
Dimensions (W x H x D) 202 x 378 x 445 mm / 7.9 x 14.9 x 17.5 inch
Net Weight 4.3 kg / 9.5 lbs
M/B Type microATX, Mini-ITX
5.25" Drive Bays 1 (Max. length of 5.25" device: 170mm / 6.7 inch)
3.5" Drive Bays 3
2.5" Drive Bays 4
I/O Panel N200: USB 3.0 x 1, USB 2.0 x 2, Audio In & Out
N200 Advanced: USB 3.0 x 2, USB 2.0 x 1, Audio In & Out
N200 Chocolate: USB 3.0 x 2, USB 2.0 x 1, Audio In & Out
Expansion Slots 4
Cooling System Top: 120mm x 15mm fan x 1 (optional)
Front: 120mm black fan x 2 (one XtraFlo is pre-installed)
Rear:120mm black fan x 1 (XtraFlo pre-installed)
*The bundled XtraFlo fans: 3-pin
Side: 120mm fan x 1 (optional)
Power Supply Type ATX PS2 (Max. length: 180mm / 7.1 inch)
Maximum Compatibility CPU cooler height:
w/o 120mm x 25mm side fan: 160mm / 6.3inch
with 120mm x 25mm side fan: 140mm / 5.5inch
*Side panel with stamping
Graphics card length: 355mm / 14 inch
3.5" Drive Bays 3
2.5" Drive Bays 4
Expansion Slots 4
Sweet. Thanks I totally missed that!
This is definitely one for my consideration
Strangely I did just come across this very case whilst browsing today and thought it looked interesting.
Would you happen to know whether it has room for a long GPU, 11 inches or so?
I have a 290 Tri-X in mine and it fits with plenty of room left over. It's an awesome little case
