Case Recommendations
8 Feb 2014
Aberdeen
I'm looking for some recommendations on a new case with cooling & possibly some bling.
I've had my current pc case for about 5 years now and it has done me well but it's time to part ways and move on, mainly because the case is a bit dented and the side panels don't fit on properly anymore, which doesn't help with the already bad cooling setup I have.
I've never been one to care what my case looked like as I cared more about the functionality of the pc than it's looks. However I'm now wanting to get a decent case where I can set up some good cooling, but also something that's not too noisy.
I quite like the look of this case - https://www.overclockers.co.uk/phanteks-enthoo-evolv-atx-glass-mid-tower-case-black-ca-054-pt.html although I don't think it will take all my drives (currently have 2x SSDs and 5x HDDs). I've already reduced the amount of HDDs in my case by 1 by removing 2 smaller drives when I bought a 6TB drive and I could reduce the amount of HDD further.
My current spec:-
i7-5820k with a Corsair AIO cooler
Asus X99A SLI Plus Motherboard
EVGA Superclocked 980ti
16GB Corair RAM
2x SSD, 5x HDDs
The case you linked will easily take all of your drives, there are 2 SSD mounts on the back of the motherboard panel, and one on the bottom right of the window, 2 hidden HDD bays and you can mount about 5 next to the motherboard too :)
I think I'm leaning towards it at the moment, unless someone can pitch some other ideas. My GTX 980 ti strobing would look good if I put in some other lights etc, although I'm rubbish at creative design or anything like that.
