Case recommendations?
18 Nov 2004
Brixham, Devon
Hey,
Have a Corsair Carbide 540, nice case, quiet and hides the PSU and ugly wiring. Only downside is that it takes up a lot of desk real estate.
Currently looking for a new case, budget is up to £200ish. Current kit is listed in my sig.
I will be looking to move to a 6700K next year (or the latest Intel CPU) and a 1070 or Vega depending on performance. Considering WC (probably hard line) next year as well. But needs to take a Corsair H105 AIO.
Needs to be quiet with a window and if possible hide the PSU...
I know not asking much is it :)
This is my shortlist so far:
Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Gun Metal
be quiet! Silent Base 800 Midi Tower Case - Silver Window
be quiet! Dark Base Pro 900 Full Tower Gaming Case - Silver
Cheers
Skilty
My vote would be for the "Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Gun Metal" as I have now to replace my old Corsair 650D. :D
+1 for the Phanteks, potentially worth looking at the NZXT cases as you can cram a surprising amount in them... I've got a 6700k build in a 450 Noctis Mid and 2 x 1080s, its pretty tight but i've got 2 360mm slim rads in there to cool it all. They're also much cheaper so you can spend more on the new CPU :)
DB Pro 900 is very tempting as well. A lot more room to work in and the case has endless possibilities.
I think I can stretch to the extra £10 if it were the better case.
Just go with what you think looks best, at the end of the day most things are about aesthetics unless you have it hidden away.
I recently changed from the same Corsair case (nothing wrong with it, just fancied a change) but I went a phanteks enthoo luxe - I know it's not on your list but it does have a PSU shroud (and built-in lighting!)
Will take a look although I do like the look of the Evolve :)
