Case Recommendations
10 Jul 2017
Hi,
I have a Carbide Air 540 at the moment. However, I'm trying to run a dual push pull setup with a 360mm radiator on the front and a 280mm radiator on the top (or the other way around). I know a push-pull isn't really necessary or useful, but I really want to build this.
This case clearly lacks the amount of real estate required to do so. So I was hunting around for cases but I haven't been able to find any.
I plan on running a maximum of 4 disks (2SSD, 2HDD) and plan to add 2x Vega GPUs when they are around.
Following features are a must:
1. Clean looks. I very much liked the look of Air 540 or Enthoo but something overly gaudy is a no
2. Mount points for pump + reservoir
A couple of good to have features would be:
1. Removable motherboard tray.
2. Tempered side panel on a single side
3. Perferred Mid ATX as opposed to full tower
Any recommendations for an appropriate case would be very much appreciated!
I'd like to restrict my budget to 300USD since shipping and customs/taxes would probably end up costing me 1k USD for a case of equal value.
Radiator specs:
360GTS XFlow - 30mm
280GST XFlow - 30mm
Even with 240mm rad, I'd need 25mm(fan) + 30mm(rad) + 25mm(fan) = 80mm of clearence.
Right. But a 240 rad is less wide than a 280 rad and 120mm fans less wide than 140mm fans, so you get more clearance going down. Hence why they only mentioned 55mm with 420, 280 and 140 rads.
This is a Fractal Define S with 1 x 360 (40mm thick) and 1 x 240 (40mm thick), both in push/pull:
http://www.overclock.net/t/1583861/fractal-define-s-two-360s/10
If you go for 30mm thick rads as you'd planned (only with 240 in place of 280) you'll get a bit more view of the top of your motherboard and RAM at the same time.
Damn.
If only this was a little bit wider :(
I guess I'll have to throw away my 280mm rad and 140mm fans. Kinda hurts a little because each fan costs around 30USD here and the rad around 180 USD
