Case requirements
23 Jul 2022
Dorchester UK
I may be asking a lot here, but I am looking for a case that can hold 8-10 5.25 HD's, 2-4 SSD's and have space for water cooling, 360 mm radiator minimum. As for budget, under £400 if at all possible, can extend budget a little.
Any help would be appreciated.
Aerocool cipher seems to fit the bill, seems a relatively new case so not great availability though
Am looking at the Fractal Design Define 7 XL, at least it's in stock at Overclockers. Drive trays for it are another matter, looks like I will have to order from mainland Europe.
Just ordered myself the Fractal Design, have also ordered a couple of extra drive cages from the Netherlands. It will be a huge step up from the falling apart Thermaltake Kandalf I have had for years.
