- 8 Jan 2009
Hi guys,
I need some advice revamping my old Lian Li PC-60 aluminium box.
I'm in the process building an i5 2500k system, likely with the ASRock Z68 Pro 3 and a GTX 560Ti Twin FrozR II
The case used to have 80mm fans which I ripped out for another system years ago.
I have access to a design workshop and (with a pack of beer) some very skilled blokes who can cut holes in practically anything. I'm planning the following operation to get this case up to scratch:
The planned setup is:
It's been a long time since I've done any sort of modding or PC building myself. In your expert opinion will this be enough to cool the setup and allow a little overclocking?
What fans would you guys recommend? I have about £10~ per fan
I was thinking of the Akasa AK-FN059 120mm Ultra Quiet Viper while they're on offer?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-059-AK&groupid=701&catid=57&subcat=4
- Remove the front USB ports at the base (I have a 3.5" card reader & USB ports on it)
- Remove the bottom drive bay
- Cut a large hole in the front panel to fit a 120mm intake fan, as long as the mount points will fit
- Cut out a hole for a 120mm fan at the top of the case
- If space allows, cut out a hole for a 120mm fan at the back. This will interfere with the removable motherboard tray & one of the hollow two piece case supports.
