I'm full aware of how many people form all over got killed in the landing @ Normandy and if any mod belives this to be a tabo subject please delet/close and let me know. How ever i pulled these images off Google ''Normandy''. These mages are the only ones i could find of the style and number and layout of cross's i want nothing directly to do with the event's and aftermath of Normandy it's self.
Okay guys need some help. Got a Lian-Li V2000B and it's massive!!! The size of this side pannle is 22.75'' wide x 23'' high (told you big case). So lets say the amount of space to fill is 21.75 wide x 22 to fill with ether of the following. This is going to go on the left hand side as you look at the case. I've a phase unit going in the base so the right side willl be cut to show all the internals off. I though with the following desings they'd let lots of air flow around the case as it'll have a rad up top for watercooling my GFX's. Just say what number pic you think is right.
It's just the cross's that'll be using okay, so the solid outline of them to be cut out via laser on the side pannel, nowt eles. Well possibly the Omean one (one with the little boy in there cos it's freaky...ooo bhooo) so just imagen the solid little white things please!!
1.
2.
3.
1.
2.
3.
