Case size issue
14 Nov 2005
Hey all,
FINALLY got my system specs all sorted..now im just concerned about the case. Originally wanted the CoolerMaster Stacker 830 Evolution - Nvidia Special Edition as the case looks pretty good and ive read some good things about it. My other choice is the Thermaltake VH6000BWS Armor+ case which again looks good.
I'll be putting in 4GB DDR3, nvidia 8800GTX, Intel Quad-core 2.6GHz, and 2x 500GB HDD. CPU cooler i've chosen is the Thermalright 120-Ultra Extreme with a 120MM fan on top.
Will all this fit snuggly into one of these cases (65CM is the max height im able to play with (also like the look of som lian-li cases).
Any advice is welcomed. looking to order in the next 2 weeks!
It'll all fit in either, I would get a Lian Li G70/A71 though personally.
Also don't get DDR3 if you haven't bought it yet, minimal performance increases and it costs loads compared to DDR2.
