I believe that the Corsair coolers are pretty good. I also think the ek ones are quite good. There are a lot of options so you should do a bit of research and you will quickly find the one that best suits. I use custom loop cooling which is good but probably not worth the cost.
The new fractal Celsius S24 is probably the one to get, if you don't mind the lack of lighting
Yeah not really fussed for lighting to be fair as I say its sat out the way more fussed for performance I mentioned in another post that I had been recommended the two corsair ones above that I suggested in here and this one was recommend to me by a guy called Frank, https://www.overclockers.co.uk/arctic-cooling-liquid-freezer-aio-cpu-cooler-240mm-hs-06b-ar.html
said it would outperform both of the corsair options I was suggested, what would you guys opinions be on this cooler looks solid to be fair? not fussed for price but yeah obviously will probably avoid a custom water cooling loop
