Swapped from an antec p180 to a corsair carbide 500r.
Here are the results:
500r is a very good case and easy to build with. Even with the case fans on full speed it is a lot quieter than the p180.
CPU temp has dropped by 3-5 degrees over the 4 cores after 1hr of prime95.
GPU temp has also dropped by 3-4 degrees.
I have 2 af120 quiets on order for the top and tempted by a H60.
Will the H60 be much better than my gelid?
max temps after 1hr prime 95 are 57-66-67-62
Finally how do i connect the 2 af120's? Will i need to buy this http://www.overclockers.co.uk/showproduct.php?prodid=CM-136-BX
