case temp monitor
20 Jul 2007
gloucestershire
i have just bought a jeantech case that has a temp monitor display in the front but im just wondering if i could read the cpu temp with this as all it is is a little probe thing or are these temp displays for case temp only ? :confused: :confused: :confused:
You're probably best off using a core temp monitor, like TAT or coretemp (perhaps Everest) as a probe won't be able to get that close.
Wooo, 4,000 post :D
If its just for show you could but if its a core 2 duo then as said above it won't be accurate.
Why don't you stick it to your gfx card or memory?
