Case that shows GPU other way round...?
31 Dec 2006
What cases will show a GPU the other way round, i.e so you're looking at what would be the fans rather than backplate... I'm thinking of the Fury X here, which to me needs to be oriented the other way so that you see the dotted panel side. There's no fan on the card, so it doesn't need to be upside down like all other cards, venting air downwards. Having trouble finding a case that does this though, and which also has a window. Can be MATX or ATX.
:confused:
Quite a few upside-down cases, which would rotate the card.
or go daft and do something like this...
What is an upside down case called... would the simply be reverse ATX?
Interesting mod... what have you done there exactly?
yes reverse atx, at the time of posting I had a brain fart and drew a blank..
the mod is an old case i/o panel, cut in half and the lower part turned 90 degrees and modified with a bit of work with a panel hammer.
the original i/o I skipped 2 rungs (should have done 3 really) cut the bottom from it then refitted with the modified part.
it was my first water build and I wanted it to be a good one
In hindsight I should have taken many more pics than I did
