Case to fit 3080
26 Feb 2013
Could anybody recommend a case to fit the 3080? Realised my current case is only 235 mm x 535 mm x 550 mm. You need about 285 to 300 w min for the 3080. I can't really remove case because of my drive bay. Even with my 1080 Ti installed, it doesn't leave much room before it hits the case.
What case do you have already so we can cross refrence ?
Budget, rgb wanted ?
I think you may be mistaken your referring to the length of the gpu not the width.
And the rest. Seems that many 380's are on or above 320mm long. To make sure that you don't restrict your choice then you need say 340mm and as yet there are no numbers for the 3090!
