Permabanned
- 26 Nov 2006
- guildford, surrey
Firstly i want the case to look respectable, because the whole family will be using the computer, no psu needed aswell, dont want ospend over £80 on it though.
allllec said:hay tom, mate i strongly recommend a lian li pc-7 (black or silver whatever you prefer) with a pair of good 120mm fans - awesome case, looks good and will cool - oh and quite cheap
Does the PC-7 take 2 120mm fans?? The description states "12 cm ball bearing x 1, 8 cm ball bearing x 1" - are they failing to mention a slot for another fan? Also, how quiet are the stock fans on the PC-7?allllec said:...i strongly recommend a lian li pc-7 with a pair of good 120mm fans...
Bananadude said:Does the PC-7 take 2 120mm fans?? The description states "12 cm ball bearing x 1, 8 cm ball bearing x 1" - are they failing to mention a slot for another fan? Also, how quiet are the stock fans on the PC-7?
