- 9 Jun 2015
Hi everyone,
I'm currently looking at changing my rig (i5 2500k+Asus P8P67) and thought it might be time to change the case: an ancient Antec Sonata.
Problem is I can't find something likely to hold a GTX970 (or slightly bigger) and less than 45 cm in height - I don't want some huge tower.
Not easy, as GPU clearance is not always clear in the product specifications.
The Antec One seem to tick the boxes, but it looks a bit cheap. Antec P280 looks brilliant, but it's a bit too big.
Any advice? Any brand, really. Budget is up to £100.
Thanks
Thanks
