Case to replace Lenovo Y710 Cube
13 Mar 2005
Hi all,
After being out the PC game for a while i bought a Lenovo Y710 Pre-built system which i bought mainly for the Full size 1070 GPU but after testing the system its ideal and works for what i need (Driving sims). Only problem being the case is a tad ugly for my home cinema setup.
Can anyone recommend me a cheapish good looking case to rebuild this in please?
Needs to take a full size GPU
This is what i have with a slight different spec:
http://www.trustedreviews.com/reviews/lenovo-ideacentre-y710-cube
Any suggestions would be great
Thanks
Enthoo Evolv ITX? I'm really pleased with my mATX tempered glass version.
You'll lose the use of the built-in Wifi though, usually the antennas are built into the case for pre-builts.
Wow that's fugly.
I have a soft spot for Fractal Design cases, they do some nice HTPC style cases like the Node series.
I have an XL in my front room, houses my server, storage and even a few Raspberry Pi boards. It's hardly HTPC style but it's plain design means it blends in. Extra bonus is should I find myself homeless I'll just move into it
ha tell me about it its definatly not a looker.
That Evolv ITX looks nice maybe a bit too PC looking if you get what i mean for my living room. Ive seen the Thermaltake Core V21 which i like the look of for its simplicity and would fit ideal with my AV kit.
Will my kit fit that case? Im a bit out of touch having not built a system in a fair few years. Im guessing that would be ok?
Thanks
