Case Upgrade ideas?? Around £100
3 Nov 2014
Newcastle, England
I am currently in a Xigmatek Alfar windowed case i bought on the cheap a few years ago, the cooling is poor to say the least even with a full setup of fans! Airflow is really bad.
So for this reason and my pc seems to overheat because of this, I am wanting a case to go along with my upgrades i am doing.
REALISTICALLY im wanting to spend around £100 on it; what is there out there for me? I want to have it as modular as possible and/or as much airflow as i can get. Also I would like to have plenty of space incase i decide to setup a watercooling loop at some point! Would like to have a window aswell if possible :)
Just give me ideas really, nothing £200< as that is silly money.
Specs are/will PROBABLY be:
AMD 8320 3.5ghz (MIGHT GET AN I5/I7)
MSI 990FXA-GD65 (MIGHT UPGRADE THIS TOO)
Corsair Vengeance 1600mhz 8gb (WILL BE GETTING AN EXTRA 8 OR 16)
Sapphire Reference R9 290 (either getting a Fury X or another 290)
Corsair CX750M (if i get the 2nd 290 ill need a new one, probably a EVGA 1000w G2)
Any recommendations or help is massively appreciated!
NZXT H440? Doesn't have great ventilation up top at the roof of the case but other than that it has a lot going for it. Great finish and all that, keep seeing builds of it and getting a bit jealous tbh
Just looked at that on the project logs and a lot of people have said it has bad airflow which is a gutter as i was looking at that too!!!
For that budget, Phanteks are a very good call, also check out Fractal Design Define R5 as iirc, they come in below your budget too.
