Case Upgrade
10 Aug 2013
Rushden
I was tired of my rig looking like a snake pit so I decided to upgrade. I went from a Cooler Master Elite 371 to an Antec P280 (which is an awesome case by the way, definite recommendation).
BEFORE
AFTER
Like I said before, I would definitely recommend the P280. It's a very spacious case and I just love it. You can also get a windowed side panel for it aswell. I'll post the link to the case below so you can check out the spec's of it for yourselves :)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-168-AN&groupid=2362&catid=160
It won't be long till Ace Modder jump in here to congratulate you on your purchase. ;)
But good to hear your happy with the case upgrade, how are your temps due to the lack of airflow from the front?
I'm VERY happy with it! I've had my eye on the Antec cases for a while now and the P280 has had very good feedback so it was the obvious choice.
I haven't checked temps or anything yet but when I get round to it I'll post results. I got the fans set up so that the 2 in the front of the case pull air in and the 2 in the top of the case push the warm air out. My rad in the rear is set up to pull air in aswell.
