hi dudes, my first post in the case bit
i need a new case for my new setup and am worried about heat, because my current setup is pants due to heat......
so i've decided between
Lian-Li PC-7 PLUS Black Aluminium
or
Enermax CS-527 Case Black
partially because they are quite cheap. I am thinking of going for the enermax, because i like the look of it. My question however, to you boffins is, is this a good case, does it ventilate well, and what fans should i use/how do i ventilate it well enough? if not then should i get the lian-li - though i dont like the look of it as much
gonna be using
athlon x2 3800
2x 1gb geil value
x1800xt
asrock dual sata
thanks in advance
or
gonna be using
athlon x2 3800
2x 1gb geil value
x1800xt
asrock dual sata
thanks in advance
