Case watercooling help
13 Nov 2012
Welling
Hi guys, in 2014 I did my first build with a custom loop and I will be swapping cases soon as my current case is a bit too big. I am going for the Fractal Design Define C as this is the most compact ATX case I could find but im not sure if my radiator/pump/res will fit in. Also what coolant would you guys recommend and is there any maintenance/cleaning I will have to do as I haven't touched it in 3 years. Thanks
Components -
Case - Corsair Air 540
CPU - Intel 4670k
Mobo - Gigabyte Z87X-UD3H
GPU - EVGA GTX 780
RAM - 8GB Corsair Vengeance Pro 1866mhz
PSU - Antec High Current Gamer 750W
SSD - Samsung 840 EVO 250GB
HDD - Western Digital Green 1TB
Watercooling -
Alphacool Nexxxus XT45 240mm
EK Supremacy Clean CSQ
EK DCP 4.0 Pump Res Combo
Bitspower Matt Black Fittings
