- 3 Sep 2014
Its been a long time since I put a big GPU Card in a computer system. If anything my previous cards have been small if anything.
*Voodoo2.
*Geforce2.
*Geforce 6600GT
*Geforce GT220.
You get the idea. So when the R9 280 came in the post I was like wow that is huge!
Tried to fit it in my Coolmaster Centurion case and it wasn't fully in the PCI-E slot. I looked at the back of the case and the back plate frames where preventing the card being fully put in. My old low profile GT220 fits in perfectly.
So I'm basically looking for a case which can accommodate a mATX board which has semi-decent back plate frames.
Not looking to spend a fortune. I rang up and the OCUK staff told me about the BITFenix Range. Are these decent? High level of compatibility?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-167-BX&groupid=2362&catid=2277
Anyway as always cheers for your help.
*Voodoo2.
*Geforce2.
*Geforce 6600GT
*Geforce GT220.
