Case window on right hand side???
27 Jul 2004
Yancashire
Incredibly simple question here. I'm looking to do a new build with a new case later this year. I would like a decent window, and I will probably want it on the right hand side, as looking from the front.
However, all cases I can see the windows are on the left! What's the situation?
Cheers bud. They do exist then. It's a case (oh ho) of just looking at the actual images then.
They're not as popular this way round obviously which is a shame.
I'm thinking of dabbling in watercooling, but as a complete novice was contemplating the pre-waterecooled case section. Wouldn't you know it, the only one with a window on the right is the most expensive and a ridiculous price at £655 :eek: https://www.overclockers.co.uk/showproduct.php?prodid=WC-028-TL&groupid=2362&catid=2728
What's it cooled by, liquid gold?
Upside down? Hmmm. That could cause issues could it not, with graphics cards being the wrong way up and whatnot?
If the motherboard wasn't 'upside down', you wouldn't be able to see anything through the right-side window because you'd be looking at the back of the mounting tray.
The 90 degree mounted ones would be my choice for air-cooling.
Bitfenix Prodigy matx has one on that side but for some reason the mitx case has in on the other side which was a stupid mistake it causes over heating of graphic cards plus you can't see in the case with graphics card blocking it.
