Im looking for a case with 8 slots, reason being is that my brother just bought a new GTX 570 and has sent me his GTX 280 to SLI with mine, nice isnt he
I have the problem with my current case in that my sound card is PCI, meaning i cannot use the second PCIE slot, i will therfor have to use the bottom PCIE slot which due to the design of my motherboard tray wont fit the GFX card. Without tearing apart a good case and using it for something else, i have decided to buy a new case.
I have found it difficult to find a case with 8 slots that isnt £100+, which is over my budget.
TL;DR
I need a case with 8 expansion slots that doesnt break the bank, or a case that allows enough space for a graphics to be using beyond the 7th slot.
TL;DR
