Case with right hand window
12 Feb 2004
Stoke
Do they make cases with the tray on the left side and a window on the right anymore, cant seem to find many , the new version of the lian li v1000 still is but i was hoping for a case like the corsair 650T thats about to come out , one that will take a rad in the top.
And i remember a few Years back there used to be cases that you could reverse !
Silverstone Raven 2, Silverstone Fortress 2, Silverstone TJ11
Edit- these can't take rads at the top of the case.
Thanks for that , looks like maybe the Silverstone Fortress 2 might take a rad in the top ;)
The Raven 2 and Fortress 2 have the same interior design and dimensions. I've seen a Corsair H50 rad which is 120mm mounted to the in the top of of a Fortress 2.
Lian li V1000 (series) if you get a right hand windowed version its possible to mount a RAD in the top with a bit of modding.
Get a normal case and swap the side panels round?
In all seriousness, go on the Silverstone site, most of their cases have windows on the right and their site is very easy to browse through.
Thanks for the comments, i never knew there were so many Silverstone cases available , build quality looks good also. Shame there arent more suppliers with RH windowed around
