Am in process of building my brother a gaming pc but he has had a pc workdesk unit fitted into one of his rooms at home and has had a specially built cupboard to fit his pc. Unfortunately the cupboard has no gap at the back or sides so cooling will be a problem.
The dimensions of the cupboard are:
inside length 495mm
height 575mm
width 218mm (197mm inside cupboard brackets
Have looked around and have found a few with large side fans but not any with roof fans; this seems like the only solution to help the cooling.
Pc will have a E6600 and an 8800gt installed.
Many thanks
inside length 495mm
height 575mm
Many thanks
