case ??
16 Aug 2009
am thinking of getting this bundle *OVERCLOCKED* AMD Phenom II X2 Dual Core 550 3.10GHz @ 3.60GHz / Gigabyte GA-MA770T-UD3P Motherboard / Corsair Dominator 4GB DDR3 XMS3 PC2-1600C9 (2x2GB) Bundle
but would like to know if my old case would fit the motherboard am taking out is a GIGABYTE GA-K8N-SLI the case its self is 33.5cm hight and 45cm length. cheers
ATX Form Factor; 30.5cm x 21.0cm that is the size of the mobo your putting into the case.
the measurments of your case would suggest it takes Matx mobo's only
Any case that says it will fit an ATX mobo will be fine, IMHO you would do better to consider what you want from a case before shelling out money on one, otherwise it could turn out to be a false economy.
Indeed; having used many very cheap cases in the past I find that if you take the bits out, turn them on their sides and fill them with charcoal they make a better barbecue than they did computer case.
not bad at cooking though. :D
EDIT So yeah, buy something decent like
http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN&groupid=701&catid=7&subcat=160
http://www.overclockers.co.uk/showproduct.php?prodid=CA-021-AK&groupid=701&catid=7&subcat=507
http://www.overclockers.co.uk/showproduct.php?prodid=CA-184-CM&groupid=701&catid=7&subcat=29
hehe, thanks.. it was kind of a backwards case mod I guess. It looks a lot better now it's painted but the pic with the flames has the most impact!
Anyway.. ahem.. sorry about the hijack.
