caselabs STH10 Problem
9 Nov 2014
So I am intending to buy a Caselabs STH10, It'll Have an X99 board with 14 Sata 6Gb ports, And I intend to use all of them! I was considering of ordering this(( http://www.caselabs-store.com/hdd-side-mount-single-wide-magnum/ )) along with 4 HDD Cages to hold 16 x 6TB HDD's... ( As Far as I know you can get extentensions that allow for more than one HDD per sata port????? ) My only question, Could I put this at the bottom of the main middle compartment under the Mobo or does it have to go in the bottom compartment where I was intending to put a 560 Rad??? If not, I'll put that in the bottom compartment with the PSU and put 2 x 560's in the roof :)
Thanks Guys.
For those Interested:
Caselabs STH10 Gunmetal
Intel Core 5960X
Asus X99 ws Workstation Mobo
3 x EVGA GTX 980 Hydro's
3 x 850 Pro 1TB SSD's In raid 0
16 x WD RED 6TB drives (If possible!)
2 x 560 Rads (If Possible)
Full dual Loop
Noctura industrial fans
3 x 4k Monitors
Corsair AX1500W PSU
Yes I am aware this is a ridiculous build, but I have the funds so why the hell not:)
As far as splitting the hard drives go, I suspect you're thinking about SAS drives where a SAS port is split off into multiple connectors. This is not the same as SATA, and the X99 WS board doesn't have SAS ports.
You'll need a controller card to do this.
Certainly an interesting looking build.
Depending on what the usage will be of those WD Reds, you might be better off housing them in a dedicated NAS unit.
