have a look on here or there is some good build log's if you search for "800d build logs"
Answer is: To space where end of long graphics cards are.Marvin, I have looked at the FT-02 and cannot for the life of me work out how a Thermochill PA 120.3 will fit....anywhere?
Just don't expect people to be eager to admit such crampedness when they've paid so much for hyped case...
I currently have a case near enough the same as the ATCS 840. I am quite tempted by the Corsair 800D and the Silverstone Temjin TJ07, just cannot decide.
EDIT: Just looked at video review and read a normal written review on the ATCS 840. Seems VERY good and it quite nice, and £100 cheaper than my other 2 choices. One question, will it fit my rad ok? as it has a stupid annoying gap between each 120mm fan, making it longer than it should be, I think it is a Thermochill PA 120.3.
I had the ATCS 840 and a PA120.3 and i can tell you that the fan spacing will mean that it is difficult to mount with out modding (not impossible just a pain). I got rid of the case in the end as the cable tidying is not as good as the corsair models for example. Other than that the case is well made and nice looking.
Double check which PA series you have, if it is the last revision before the TA then it means you have 15mm fan spacing which will allow it to fit in the ATCS. If you have an older revision of the PA then the spacing will be larger and you will not get it to fit with the provided ATCS mounts and fan mount holes.
