Cases for a 360 rad?
12 Feb 2007
South Shields
What are my case options for mounting a 360 rad, preferably on the roof or similar in the case? I currently have a Lian Li PC-a17b, and like the clean look. So no Antec 1200 or worse cases! I do have a card reader, DVD and a fan controller to also fit in there.
Options please! :)
Get the 700D was going to suggest the coolermaster atcs 840 as an alternative but I'd rather have the 700d.
The CM 840 Does indeed come with brackets for top mounting of a 360 rad, also has mounting for a secondary 240 rad next to the HDDS.
I currently have mine with an XSPC RX360 in the top :D
Don't really have a budget! If the right case comes along, I will probably go for it!
Is the CM840 the same as the ATCS840?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-159-CM
Hmm, between that and the 700D, although I would like a windowed panel, but would have no use for the 800D hot swap bays and the like, since I run WHS.
I know I could mount the rad in the front of my Lian Li, but want to keep everything in the case, including fan controller, card reader and dvd drive (I also have 2 storage drawers I keep CD's in there!)
Well, I have went for the 700D in the end.
Cheers for the help! Now I just need a windowed side panel :D. Anyone care for a swap?
