Cases for a 4090 build with EATX mobo?
25 Feb 2023
London
HI,
I am looking at a 4090 build with a Z790 Godlike mobo.
The mobo restricts my choices for cases. This will be an aircooled build. I have found the 7000D from Corsair but are there any other appropriate cases?
Thermaltake Core P3 TG Pro or Core p6
open air case, so you don't need intake and exhaust fans,
also support up to 420mm rad if you decide to use aio cooler
Edit, and support noctua nh-d15s, if you use i guess.
Got a corsair 7000d airflow so far I'm happy with it as I needed room for a 420mm aio and 4080.
Corsair iCUE 7000X​
Fractal Design Torrent was what I got when looking for a case for a big build, I needed E-ATX - SSI-EEB (a lot of cases just say 'E-ATX' which isn't really a standard, SSI-EEB was the actual mainboard size)
HI,
Phanteks P600S, simply an awesome case, the best I've ever worked with, personally and professionally.
HI,
If the 7000D is similar to the 750D it will be a good case. I have a Corsair 750D and rate it as the best case I have used although I have not looked at any of the modern cases of recent years.
I generally try to buy cases second user that have been well looked after so I am always a couple of years behind current tech.
011d xl fits eatx
phanteks nv7
Upcoming cases
Phanteks nv9
011d evo xl
Both Upcoming cases support 3x 140mm
Instead of 3 x 120mm
Even if not watercooling 140mm fans
Is a good option
