- 27 Jan 2012
- The king of the north!
Hello ladys and gents. Since im working again i decided i would re visit the ole hobby and build a new pc. I currently have a Phantom 820D, however i have always loved the temjin Tj--- series and especially the 11. So unless you guys think it wouldnt be wise i think i will be changing my case to the Temjin-TJ11. I have bought the motherboard and Cpu and a temporary cooler
Msi BigBang xpower II
3970X
NH-D14
the cpu is due to arrive next Saturday (23rd) and can happily provide proof of ownership then as i am aware a few people get time wasted on dreamed up rigs that don't come to light (a shame really because most of them are lush)
i am running a Evga gtx 680FTW+ on this pc at the moment but plan to get dual titans and a new power supply at the beginning of may.
Now for the cooling from looking around i cant find any titan water blocks as of yet. I do want to have the entire rig Cpu and Gpus watercooled and if anyone can enlighten me if i can or cannot remove the silly gun heatsync and watercool in it's place on the big bang that would be great if not i will have to deal with it i guess
If i get the Tj11 i know that i can fit a 5x120MM Rad and dual 2x140MM Rads into it without any real modding and am more than capable of getting that all mounted without much fuss. The part i struggle with is matching up all of the fitting tubing but i can give you a bit of personal preference
1. Money isn't a issue.
2. I would prefer to have compression fittings as i think they look great however if needed to fit into tight angles or other situations im more than happy to have other forms of fittings
3. I would like to have a "dual pump mod kit" i believe they are called (having two pumps running one loop)
4. What Waterblocks would you recomend for the cpu ( i can research the titans when they start to launch)
5. As i have said i would like to be able to remove the silly gun sync on the Bigbang but if it's not a possibility then that's fine
If there is any questions or stuff that you want to ask me then feel free that's about as much as i can think of on top of my head ps here is attached a picture of the components said in this as proof of ownership
3970X
NH-D14
black and white all round. Also sending out some dominator platinum having the metal fin on top stripped down and my online handle engraved on them!
