Cases with pre-fitted custom fan colours
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Just because blue is cold and depressing looking. You can have other choices now!
CLICK HERE FOR THE FULL RANGE!
Here are a few select options.
OCUK Freeze Box - Antec 902 Gaming Case (Purple LED Fans) @ £124.99 inc VAT
The return of a true classic, the OcUK Ice Box range of modified Antec Nine Hundred Two Ultimate Gaming Cases offer superior cooling and noise performance.
The classic Antec Nine Hundred Two chassis as standard offers industry leading cooling performance. Able to cool any hardware to previously unheard of temperatures with the standard fans, only OcUK could be mad enough to improve on this!
Combining the excellent Xigmatek 120mm Crystal LED Fans which move a massive 68.33CFM each at a whisper quiet 20dB, with the Antec Nine Hundred Two chassis takes the cooling performance to a whole new level. Be prepared to stun your friends with the stunning light show that the LEDs on the fans produce. Deep and vibrant colours make the case light up and a true sight to behold.
The fans are pre-installed by our expert system technicians and pre-tested for acoustic and cooling performance before shipping to ensure the highest levels of build quality possible.
Antec 902 Gaming Case:
- Three performance Xigmatek 120mm Crystal White LED Fan 120mm fans
- Unique Top mounted 140mm TriCool exhaust fan to cool the hottest systems
- External 3 x 5.25"
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
Xigmatek 120mm Cooling Fans:
- Frame dimension 120 x 120 x 25mm
- Fan speed 1500 RPM
- Fan airflow 68.33 CFM
- Connector 3-pin
- Voltage rating 12V
- Noise level 20dB(A)
Note - All of our Ice Box cases are built and installed on demand, during busy periods this may cause a delay of 24 hours in despatching your order. Each Ice Box system has its case cooling hand modified by our expert technicians for cooling and acoustic performance.
Only £124.99 inc VAT.
ORDER NOW
OcUK Ice Box - Antec 300 Gaming Case (Green LED Fans) @ £69.98 inc VAT
The return of a true classic, the OcUK Ice Box range of modified Antec Three Hundred Ultimate Gaming Cases offer superior cooling and noise performance.
The classic Antec Three Hundred chassis as standard offers industry leading cooling performance. Able to cool any hardware to previously unheard of temperatures with the standard fans, only OcUK could be mad enough to improve on this!
Combining the excellent Xigmatek 120mm Crystal LED Fans which move a massive 68.33CFM each at a whisper quiet 20dB, with the Antec Three Hundred chassis takes the cooling performance to a whole new level. Be prepared to stun your friends with the stunning light show that the LEDs on the fans produce. Deep and vibrant colours make the case light up and a true sight to behold.
Antec 300 Gaming Case:
- Three performance Xigmatek 120mm Crystal Green LED Fan 120mm fans
- Internal 6 x 3.5" for HDD
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
- Connector 3-pin
Only £69.98 inc VAT.
ORDER NOW
OCUK Frosty Box - Antec 1200 Gaming Case (Red LED Fans) @ £179.99 inc VAT
The return of a true classic, the OcUK Ice Box range of modified Antec Twelve Ultimate Gaming Cases offer superior cooling and noise performance.
The classic Antec Twelve chassis as standard offers industry leading cooling performance. Able to cool any hardware to previously unheard of temperatures with the standard fans, only OcUK could be mad enough to improve on this!
Antec 1200 Gaming Case:
- Five performance Xigmatek 120mm Crystal Red LED Fan 120mm fans
- 13 drive bays
- External 3 x 5.25"; Internal 9 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 9 x 5.25"; Internal 3 x 3.5" for HDD or
- External 12 x 5.25 for HDD
- Internal 1 x bottom-mounted 2.5" SSD drive
- 200 mm Radiator mount
- Perforated front bezel for enhanced air intake
- 7 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Maximum video card size: 17.5" / 444 mm (Note: some video cards may require removal of the adjacent hard drive cage)
- 2 x USB 2.0
- 1 x USB 3.0
- Audio In and Out (AC'97 and HDA compatible)
- Connector 3-pin
Only £179.99 inc VAT.
ORDER NOW
coolermaster dominator is a nice one you could offer
haf aswell
would be better if you could photoshop a gif of a case changing between red/blue/green/white etc....
Good idea Ace Modder :).
Personally on all the cases I've bought in the last few years all the stock fans have gone straight in the bin as they're either too noisy or just don't shift enough air.
Would be nice if I could buy the cases without any fans, so saving me a couple of pounds (obviously not loads as the stock fans are only cheap) and saves the planet from me chucking them in the bin! I just don't like the idea that I've paid for something that I don't intend to use!
I think it would be quite cool if you made it possible to put these into your system configurator with an option to upgrade to the BitFenix sleeved extension cables in the matching colours :p
Not something I'd buy as I wouldn't buy pre-built, but I reckon it would be a good choice!
Lancool range would be nice :)
Also how an earth did you do the lighting on the Purple Case... Mine is 100% nowhere near that bright even in real life... My Blue LED power light can be seen in places over the Xigmatek Purple LED's...
kd
