Cases with the same internal structure as Centurion 53x
Its not going to a PC7+ if your thinking that, you want a side mounted HDD cage :p
Also does it have to be EXACTLY the same, or does very similar like the internals of the Antec SLK3700BQE cut the mustard?
Ok here is a controversial idea, Antec 1650 with some heavy modding to the front panel.
Would help if I had a budget to work with, or else I will say the Silverstone TJ07 next :p
Hmmm, some of the thermaltacks might fit the bill, have a browse of there website as they may have something your after.
Although have you considered a old Chieftec Dragon / Scorpio type case, as I am sure one of thoose would be a brilliant case for some dangly hdd modding fun.
What cases do you like the design of, or are you yet to find any?
So a plastic 110 would suit your needs quite well..... or a steel one.
Kingwin USED to do one, but it was discontinued in about 2001/2002 which is a steel look alike 110/201 hybrid. Looked quite good for a value case although its name aludes me so is not much help, sorry.
Haha I am keeping my eye out, just cant think of anything that would suit you exactly. You had a look on the Chieftec website? And all the other major manufacturers?
Randomtom is waiting on the TJ08, looks set to be a cracker and is a good size, just you can be sure it will be the usually high priced silverstone affair :(
I know what you mean, finding a case which you think is proportioned just right can be a pain.
How about the Asus Vento in green? Ok maybe that was taking it a bit to far :p
The Akasa Eclipse is way to big im guessing, as it is in the same sort of proportions to the Chieffy cases you looked at, just bigger!
TJ08 will be available in black. :)
