Casw window scratches
Assuming the OP means the really fine scratches often seen in case windows from wiping dust etc away, then the 600 and 1200 grit paper will be too aggressive. I'd probably go straight to the polishing stage. Rather than metal polish, I would say that a finer car paint polish would be better as well.
Lots of information if you google on polishing acrylic!
