For solid or stranded, and 1, 2 or 3 piece?
solid cat6 has a different awg than stranded, so won't fit.
The plugs differ for solid or stranded use.
Yep with CAT6 cable though "most" of the time if you buy half decent (2 part or greater) connectors they will work on both, here is also an overseas retailer selling the same connectors i pointed to and specifically saying the are suitable for both.... http://www.showmecables.com/product/Cat6-Connector-With-Guide.aspxThe issue is that a plug for stranded is designed to piece through the strands to form a contact, it can't do this with solid core cable, hence the plugs are different. The contacts for solid are split so they go around the solid core on both sides to conform.
My experience has been the opposite! I've found it hard to find the type suitable for solid.
Definitely get the ones with the inserts.. Google RJ45 with inserts.
Makes life a lot easier, and less prone to making errors.
https://www.youtube.com/watch?v=ymBNtDj7J4Q
That load bar was the biggest pita when I used it on cat6 cable. They are so tiny and if you hold it aligned next to the strands there was one that wouldn't fit. Maybe I should have cut it diagonally like in the video and inserted the wires individually. Glad I will never have to do it again as I only needed to insert a plug so I could use a coupler to extend the cable.
