Apologies for yet another LOAM PC problem thread, i'm having some real grief with this POS atm, Since installing the latest Cat drivers 7.6 I can no longer launch CCC. It seems its a known issue
737-26494: Radeon Series - MOM.implementation or CCC.implementation appear after installing Catalyst Software Suite
and Ati/AMD suggest that you remove .Net 2.0 and the drivers followed by re installing them which all sounds nice and easy except you cant remove (or i cant) .Net 2.0 as windows tells me that it is in use then halts (even in safe mode it does this). All ive been able to do is repair it and reinstall the Cat 7.6 drivers, none of which has done anything to get CCC working again.
Finally I know its a driver issue as I tried 7.5 and its fine, i would use it but there's a terrible open GL bug when using a 2nd monitor.
Any thoughts before I throw this rubbish 2900 out the nearest window, I can honestly say that its been the worst card i've ever had the misfortune to own, Its getting to the point where I wish it was faulty so it could be returned.
LOAM
LOAM
