Hi all - thought I'd run a 15 meter cable around the house (while the wife wasn't home
quite happy with myself then realized there was no signal from the
ASUS RT AC3200 (virgin media hub in modem mode) and the cat 7 cable - its a brand new cable that says is backwards compatible etc so thought would be advantageous to get this over Cat6 etc....
Am about to return it - is there a major difference.. swapping ports with the other cat 6 cables work fine so it seems the router it doesn't like the cat 7 cable.
Anything to change in router settings before I return it and order a different (cat6) cable ?
Thanks in advance.
Thanks in advance.
