cat drivers needed please...
Permabanned
11 Mar 2004
i have just installed a new OS and have just tried the omega drivers for the first time. my 3Dmark 05 score on my X1800XT 512 has dropped from 9200 to 8200 and im not to impressed...
looking for links to cats 6.1 6.2 and 6.3 please. cheers.
www.ati.com, they are all there, and even the control panel (if so inclined). Search under "previous drivers" ( and remember there are more than one page).
Look under "fire MV" for the control panel.
step 1) load browser
step 2) type google.com if it isnt already your homepage
step 3) type ati
step 4) click 'drivers for xp'
step 5) download and install
:rolleyes: :D :p
If you don't want to use the awful CCC:
If you're using XP x32, download the drivers from ATI's website via "Drivers and Software" -> "Windows XP" -> "Windows XP Drivers and Software" -> "FireMV" -> "Current Microsoft certified WHQL Drivers"
Download the "Display Driver, Control Panel" (link, direct link to exe, 22MB)
If you're on XP x64 then it isn't that simple unfortunately as the drivers without the CCC aren't listed under "FireMV"
Instead, download and install 5.11. These are the last drivers without the CCC. When this is installed, download the latest Cats (6.4) with the CCC. Don't uninstall the 5.11 drivers. Install the 6.4 drivers over the top, but ensure that you do not install the CCC (select Advanced install and uncheck it). Bingo, latest drivers, with just as good performance as with the CCC but without the bloaty memory hogging CCC. This is my current setup
I only upgraded from the 5.11 drivers to the 6.4 drivers as for some reason I couldn't select AA for Tomb Raider: Legend and Oblivion with the older drivers (works fine with the later drivers)
Is this the page u were looking for?
http://www.ati.com/online/403/leech.asp
