- 25 May 2008
- North Wales
I want to get a cat flap but our utility room door is a UPVC paneled type and i'm not sure the best way to go about it. In a flat panel fine but as the cat flap will span over the panels i'm not sure how to seal it other than liberal application of silicone and i'm worried about it not being weather tight or just looking botched.
This is the door
And this is a close up, the one i'm looking at needs an opening of 167mm so it'd just annoyingly be hanging over both edges
Also as one final thing i can't find a microchip catflap anywhere in any colour other than white or brown. As the outside of the door is anthracite grey i'll need to get a can of spray paint to make it look not terrible but that's by the by.
So any advise?
This is the door
So any advise?
