cat5e faceplate proximity to power socket
25 Oct 2007
How close is too close or doesn't it matter?
I'd like to mount a VDSL modem close to a power socket too. Is there a minimum distance?
my fttc modem is about six inches from a power socket as is the master socket and a two port surface mounted faceplate, I have no sync problems.
Sareth, there doesn't seem to be an official recommendation anywhere so that's good to know, thanks.
Doughnut007, trouble is, as I understand it, the cable would have to be shielded aswell and the lot would need grounding for the shielding to be effective.
