- 17 Aug 2010
Hey,
Im moving house and want to know what cable to use, i will only be using it around the house and up to 1gb speeds. The cable will mainly be used for network streaming of movies and songs and just playing casual games etc.
So should I use cat 5e or cat 6?
I will need to run my cabling outside of the house and up the walls do i need to buy shielded cabling for this or is any okay?
Thanks for any guidance you can give
