Greetings,
As my first post on this forum, I come to you with a question. To summarise, I will be setting up a small home server for projects and such in the garage. The only wired access point via Ethernet for this is at the other side of the house. Due to this I have ran a 50m Ethernet cable around the house to get to the router. Once I connect the machine, it seems to be not receiving any kind of signal through the cable. I have tried connecting the cable to my laptop and it is all working perfectly and the lights on the ports on both end are flickering. When I go to connect this back to the server machine the lights on the Ethernet port do not light up on both the router and the machine. I was thinking that the machine is not capable of outputting enough power to the cable to send the signal through it, as it's using a built-in Ethernet adapter in an old Foxconn motherboard. I was thinking of trying a PCI Ethernet card and seeing if that does the trick? Last of all, It's not a 'server machine' so to speak. More of an old computer being used for server purposes.
If anyone has any ideas or suggestions for me, fire away, they will be much appreciated.
Thanks in advance
Thanks in advance
