catalyst 6.11
2 Oct 2006
do these work with folding?
my brothers got the x1900xt that was and still is giving me headaches, it refuses to fold any faster than 8mins-ish, i cant work out what it is and as he has it now the only thing i can do is get him to do software updates really
err, mines about 11-12 mins a frame, isn't 8 mins good?
btw the software will not effect it.
2D speeds should be giving around 8 minutes a frame... 3D got me about 6.5 minutes. Running at 670 and I am getting 6 minutes per frame. I think this could be higher but my graphics card's memory refuses to overclock past 750.
SiriusB
ye i was pretty sure it wasnt running correctly, im not guna waste a thread on it anymore as ive already done that once anyway :p just want to know if these 6.11 drivers work with folding, if they do i'll get me bro to install them on the off chance they fix whatever is holding up folding on it
at 2d speeds it does each frame in 9mins, when its set to 675/800ish via driver level, ATT .955 or something, the recentest release before i had to give it to my bro, 1.4vcore/2.01vmem, it does them in 8mins, i dont know whats holding it back, the rest of the pc is;
DFI RDX200 mobo
opty144 @ 3.1ghz
1gig g.skill@275mhz
blahblah
it is using cat 6.10's
it may well be an issue with the rest of the pc or something i installed, i dont know, i cant mess with it now really as he has it for his uni work to do on it now, which is why i gave up asking stuff in other thread :) just thought on the offchance its some catalyst issue with the rest of my pc then if the 6.11's are folding compatible i'll get him to update to them just incase, which is why i still want to know if 6.11's are compatible! :p
Maybe you have a gremlin in your PC, cos I overclocked mine with no problems. Only issue I have is sometimes it reverts back to 2D speeds! Bit annoying.
SiriusB
gonna go check for the latest ATT see if that sorts it
ok new ATT worked fine.
can you say 688.50/855 !
They can go to 80!? Wow... might see about pushing the OC higher, but I suspect it wont. I have RAM that wont go past 750 and I think I've just about hit the limit of the core at 670 :(
How high can you safely push the voltages on an X1900XT? 700MHz would be awesome :D
SiriusB
Is the fan at 100%? If not, crank it up!
May also need to get better airflow in the case.
Failing the above, new cooler time :D
SiriusB
fan at 100%
airflow, 120mm in, 120mm out and the PSU out 120mm low RPM as well.
its just odd, I'll up the voltage, see if that works!
