Catalyst Control Center - Install..yes or no?
27 Apr 2014
Quick question, I have an "MSI Radeon R9 270X Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card".
I usually disable Catalyst Control Center from starting, should I? What does it do exactly?
It let's you manage display and application/game settings. Personally I'd rather have it installed and running then not.
Thanks. I kind of guessed that part, but was more wondering if it does anything other than that (performance or feature enhancements etc) as I only ever use default settings/profiles?
it lets your gpu downclock at idle aswell,without it it will run at full speed/voltage
far as I know it wont enter idle clocks without ccc
Unless you are having problems there isn't really any reason to turn it off / prevent it from starting.
I had the extact opposite problem in that it wouldn't start. You could select it and then it would simply do nothing. A tad problematic given I couldn't setup my Eyefinity group without it. Got it working finally although now it won't switch profiles.... :o
I have a work around so no real biggy.
